Author Topic: Tracking Middling the ball - Coach and player improvement  (Read 815 times)
Mpt7
« on: October 06, 2017, 09:36:14 AM »
Hi All,
has anyone come across something that will track or show where a ball hits a bat?
I have a group of players, including myself, who don't know where they hit the ball on the bat. it can be used as a tool to explain how to improve technique or to decide where you want a middle on your bat
any help would be appreciated, cheers
Matt
Re: Tracking Middling the ball - Coach and player improvement
« Reply #1 on: October 06, 2017, 09:51:27 AM »
Get a middling bat made up to your bat weight?  Shows you if you're middling it. Or seen some people cover balls with white board marker as it'll rub off on the scuff sheet when you hit it
roco
  • Trade Count: (+16)
« Reply #2 on: October 06, 2017, 09:56:02 AM »
Crich tech sheets do this if you can find any
They go on the bat like a temporary scuff and mark black where ball hits bat and are easy to take of afterwards .
The first cricket box was used in 1874.  The first cricket helmet was introduced in 1974. So, it took 100 years for men to twig that their brains were also worth protecting.
« Reply #3 on: October 06, 2017, 10:07:23 AM »
Video? Will help with the technique side too. Plenty of 50 go pro copies that will do the job
The main problem with trying to see where you make contact with the ball (presumably indoors) is that you'll be off compared too playing outside.
Surely the real solution is to keep buying bats until you find one that is all middle? :)
roco
« Reply #4 on: October 06, 2017, 10:25:17 AM »
https://www.crictech.com/pages/analysis-design
that's what I used if its what your talking about
Mpt7
« Reply #5 on: October 06, 2017, 10:26:28 AM »
@ dorsetdan - always found an ipad as the most effective tool for video recording although they are always filled pretty quick. always willing to try a cheap goPro though any recommeded and what do you use to watch them back?
@TomLine - that quite a cool idea. I already have a middling bat on order from our friends at H4L so can try both approaches
@roco - cheers. emailed crictech let's see what they comeback with. these seem to hit the nail on the head.
and yes @DorsetDan - the only real solution is having a bat which is an all over middle - the search continues . I think we need to breed some wood with a trampoline! it's the only appropriate solution
Australian fast bowler
« Reply #6 on: October 06, 2017, 11:09:06 AM »
i used Impact stickers for golf and just loaded them up on the face, obviously was about 8-10 stickers but it did the job to see where i hit the ball the most
« Reply #7 on: October 06, 2017, 11:10:56 AM »
That's a pretty good idea
  • www.twitter.com/thewoodyspin
« Reply #8 on: October 06, 2017, 11:48:08 AM »
Yeah i thought impact tape, then i got googling. Apparently masking tape works well, just dont press it down, lay it on and let it stick?
Also sprat on foot powder was a suggestion? My be worth looking on a golf forum for further?
« Reply #9 on: October 06, 2017, 03:59:17 PM »
I bought one of these when it was on offer. Still not expensive though.
https://www.amazon.co.uk/Underwater-Waterproof-Wide-Angle-Batteries-Accessories/dp/B01JS00NFE
I'm fairly sure you can stream the video to an ipad/ laptop but I haven't used that function yet. Personally I prefer to set it up and leave it running to look over later and the quality of the video is more than good enough to work out where you strike the ball and how technique sits along side that.
On the bat side... I guess the answer is to raid one of the more privileged members collections at the next CBF net :)
