Pages: 1 [2] 3
Author Topic: Monster Aldred Butterfly and Red Ink - 2 more for the collection  (Read 1816 times)
Re: Monster Aldred Butterfly and Red Ink - 2 more for the collection
« Reply #15 on: October 24, 2017, 08:25:41 AM »
Good to see a bit of experimentation with different bats over the Winter :)
I thought I was settled but having handled a few Aldred's at the CBF net I think I might give one a go, mainly for the handle and very "solid" feel. The rebound of a ball was also consistently very good across all bats I've seen from him. The next most similar in feel in general would be Hunts I reckon as both feel like very sturdy bits of kit. The handles just tip it in Aldred's favour though and is the main reason I'd like to try one.
I'm not sure I could cope with getting a custom direct though as the might be some differing opinions on a few things ;) I may have to badger some forumites at the next CBF net instead :)
« Last Edit: October 24, 2017, 08:27:15 AM by DorsetDan »
« Reply #16 on: October 24, 2017, 08:42:38 AM »
I was thinking of getting a Jedi so I would be interested in your thoughts on your one.
I only had a quick feel of a couple but they were all right up there as some of the best balanced bats I've had my hands on. I would say they have more in common with a TK/ Newbery "weightless" feel as compared to the Aldred/ Hunts "rod of steel solidness" feel. Feel is such a personal thing but that would be my impression. No idea on performance or durability of Jedi (which judging by old forum posts may be the only thing to watch)
« Last Edit: October 24, 2017, 10:28:03 AM by DorsetDan »
BatGoonMcClintock
« Reply #17 on: October 24, 2017, 10:18:48 AM »
I am. My Supreme has quite a high middle and a duckbill and it does pickup well. I find cross batted shots easy and it's performance is rivalled only by my Red Ink.
I don't think he pushes heavy bats as such. I think he suggests ignoring dead weight and going by feel. It was a revelation for me and I haven't looked back since.
@Gurujames I was on the fence on this as well.  However, having 8 bats around the same weight and knowing that Aldred made a fantastic butterfly, I just wanted him to make me one without me imposing restrictions on him.  I took 3 of my bats with me to get a feel and compare the pick up of the one he was making.  I made it a point to never look at the scale.  Just wanted something big and solid and that pinged and that was within ball park of the rest in terms of pick up.  And while the bat he made felt a bit heavier, I didn't mind because it still felt great.  I never thought it would be 5oz higher than the rest of the bats!  So yes, I am a convert.  He never pushed anything on me.  He only suggested a thicker oval handle than the other bats because he said thicker handles meant more power transmitted to the ball.
It's easy to see where the extra weight is and why it doesn't matter as much.  Off the 5 oz extra weight, about 2 is in the handle, another 1 to 1.5 is in the top of the bat (shoulder, splice, sticker) where it is noticeably thicker than other bats and only 1.5 to 2 oz on the blade which still makes for a thick blade.  The toe on my bat is 31mm at the center, 25mm toe on the edge, edges are 39.5 mm, there's a 3-4mm camber on the face.  So it is a massive bat but doesn't feel like it because it is beautifully balanced with the extra weight distributed evenly across the bat.  The balance point on the Aldred is also about a 0.5 inch higher than some of my other bats.  And I think the axe-like handle makes a huge difference in how the bat picks up and feels.  And it's the axe-handle that gives it the solidity that others have mentioned.
If you request a lower weight, Aldred can't bring these factors into play that make the bat feel good.  I'm optimistic, I can experiment because I've got other bats that work for me and if I can get this to work, it will be a welcome additional to the arsenal, a howitzer to the pistol collection.
I get it that Aldred is not everyone's cup of tea with the heavier dead weight bats but the lighter pick up is definitely not (No Swearing Please).  I had no pressure to pick up my bat, if I wasn't happy, I could've asked him to shave off a few ounces from the bat.  Yes, I was taken aback by the scale weight when I first saw it but the more I swung the bat around, the more I wanted to give it a chance as it really didn't feel THAT heavy.
I will say that if you haven't had a bat made by him in person and seen the process, you are doing him a huge disservice by disparaging his skill in producing a balanced bat.  At the end of the day, it's a good performing bat that counts regardless of weight.  And if you can swing a 3lb bat the same way as a 2lb 10oz bat, why would you give up that advantage?
@DorsetDan Yes, I second that, winter is for experimenting.  Totally agree with you and @Gurujames on the handle making the difference in feel and immensely aiding pickup.  I also feel that an Aldred handle works better and differently than putting on an extra 3 grips, I used 2 grips on my bats before and absolutely hated it and this doesn't feel the same.  Another bat with a thick oval handle is my Hunts and lo and behold, that picks up awful light as well.  Several people have said the Hunts picks up better than my BB even though it weighs 0.7 oz more.
When is the next CBF nets and where?  If it is indoors and within say 30 miles, I might have a go.  You should definitely get an Aldred personally if you get a chance.
I only had a quite feel of a couple but they were all right up there as some of the best balanced bats I've had my hands on. I would say they have more in common with a TK/ Newbery "weightless" feel as compared to the Aldred/ Hunts "rod of steel solidness" feel. Feel is such a personal thing but that would be my impression. No idea on performance or durability of Jedi (which judging by old forum posts may be the only thing to watch)
@DorsetDan I would second your view of the JEDI, very well balanced and pressed to provide an awesome ping.  Soft pressed so needs more knocking in.  In terms of ping out of the packet, the Aldred and JEDI stand out from my other bats which are not too shabby either.  Can't comment on durability but hopefully we will know in a year.
TCB
  • UK Handmade English Willow Bats
    • The Cricket Boutique
« Reply #18 on: October 24, 2017, 11:41:46 AM »
Personally I have 2 Jedi bats (a Zaramx and and Abalest) in lower grades (Elite). They both pick up really well and the ball fly's off.
As I'm sure you are aware I have also handled a few Aldred's and they are well made and do have very thick oval handles as standard. Personally I thought they picked up closer to their dead weight but again that is my opinion and bats feel different to everyone.
English Willow, Handmade Cricket Bats. www.thecricketboutique.co.uk / @thecricketbtq / facebook.com/thecricketboutique/
« Reply #19 on: October 24, 2017, 12:18:14 PM »
I've said this before, but this forum was established to support batmakers like Jedi and Aldred. :)
I've only used one of his bats, but I sometimes wonder if Paul Aldred is being punished for being too good at his job? In days gone by, cricketers (even pros) did not know how much their bat weighed; they just chose them by picking up a few and going with one that felt right.
moonball
  • Pitch it up, get your reward.
« Reply #20 on: October 24, 2017, 12:21:49 PM »
I too have had experience with Aldreds... I do like Paul's thick oval handles, I'm a two and a half grips man anyway. I haven't used/owned any Aldreds, but have knocked two in and refurb'd one (both owned by a lad at our club). They do pick up nice, feeling just under their dead weight, certainly the Spectre does. But, having three JEDi with a fourth on the way, I can't speak highly enough of the quality and service, having met James, been to the workshop, etc. Also, TCB have sorted me out with three of those (technically two, with one on the way!) and the service is fantastic, almost bespoke. Top bats for the money, not sure there are any bats out there offering the same value for money and performance, with the lower grades being offered for peanuts, you can choose your cleft, etc. Can't speak highly enough of TCB.
Three JEDI with one on the way.... I guess it's a case of may the fourth be with you.
moonball
« Reply #21 on: October 24, 2017, 12:23:05 PM »
Some pros still don't.... Quinton de Kock for example. He has no idea what his bats actually weigh.
BatGoonMcClintock
« Reply #22 on: October 24, 2017, 12:48:26 PM »
@Bats_Entertainment Certainly seems like it...within reason, I think dead weighters are missing out....What possible difference is there between 2-8 and 2-11...that's 84 grams or a packet and a half of crisps...is anyone really saying that anyone can tell that difference?...It's most certainly feel....I think people like a bat's feel, weight it and then think it's the weight that's the most important.
I've used the Jedi and I second @moonball and @TCB sentiments....in fact, he's a hidden gem is James Dollive though with IJC popularising Viking, he won't be a secret for much longer.  Having said that, I think I'm confident that if I walked out with any one of my 8 bats, they will do just fine.
« Last Edit: October 24, 2017, 01:11:03 PM by BatGoonMcClintock »
« Reply #23 on: October 24, 2017, 01:00:16 PM »
@Bats_Entertainment Certainly seems like it...within reason, I think dead weighters are missing out....What possible difference is there between 2-8 and 2-11...that's 84 grams or a packet and a half of crisps...are you really saying that anyone can tell that difference?...It's most certainly feel....I think people like a bat's feel, weight it and then think it's the weight that's the most important.
You are somewhat correct about this although In my case, I use a weight that is the top-end of my physical ability without impacting my timing. I have top edged very quick short balls (when pulling) in the grill of helmet using a bat two ounce heavier than my regular weight. I am able to hit sixes just fine with my regular weight bat or an ounce lighter. There difference between a 2-13.4 and a 2-11.0 bat is negligible but it slows me down a little when it comes to facing quicks. The "feel" bit is subjective but I have noticed a tangible difference in my response time.
TCB
« Reply #24 on: October 24, 2017, 01:47:21 PM »
Thanks  :D
« Reply #25 on: October 24, 2017, 01:47:41 PM »
A note on Aldred - just because he makes a lot of heavy bats doesn't mean he only makes hevay bats, my Silver Sovereign is 2.10 fully dressed and a beauty, and I've had hands on several others of similar or lighter weight. I will say that I'm not nearly such a fan of the heavy/super light pickup ones though, the feel isn't quite what I like.
More topically, the Red Ink's a beaut!
BatGoonMcClintock
« Reply #26 on: October 24, 2017, 02:05:54 PM »
The Red Ink was superb in the first hit, there are a few cherry marks on the edge but a few off the middle as well and those were right out of the screws.  And it's 2-11.8 but because of the shorter blade, doesn't seem heavy at all, felt no different than using my 2-10 BB
The Aldred has a shorter blade as well.  Perhaps this helps pick up a bit.
In any event, I'm not taking any chances and I'm hitting the gym hard and will net with the heavier Aldred but also practice with the lighter bats and see how I get on with them and what pace is too quick for the slower reaction speeds of a heavier bat.  In my league, the main problem is the slow dibbly dobblers, not the express guys.  Very few top 65 mph.  So the Aldred is meant to be an enforcer for the spinners and the 55mph outswing bowlers.  I might even swap bats midway through an innings, start with a light weight bat and after seeing off the opening quicks (if I survive), call for the enforcer.  On the other hand, if the quicks keep it up, the Aldred will be very handy playing punchy drives.  Decisions, decisions....or mental masturbation...depending on your point of view.
The plan is to work on the fitness and use the extra strength to deal with the heavier bats.  Perhaps in doing so, I will improve the bat speed on my lighter bats.  But hey, nothing ventured, nothing gained.  The Aldred is a science project as much as anything else, All for science!
moonball
« Reply #27 on: October 24, 2017, 02:34:25 PM »
55mph out-swingers.... you've seen me bowl then!
BatGoonMcClintock
« Reply #28 on: October 24, 2017, 02:38:31 PM »
I hate the 50mph outswingers even more....can never get them away, no pace at all to work with and my timing on slow bowling is rubbish unless it's a rank half volley.
« Reply #29 on: October 24, 2017, 02:54:26 PM »
Thanks for the feedback, glad it went well in the first net.
The weight vs pick up conversation is an interesting one. Yes there is very little in terms of actual weight difference between 2-3 oz as others have said but its down to how heavy it feels. For me personally, I think there is a suitable range for everyone within 1-2oz. Anything above or below this weight will impact on how you feel as the innings goes on or your shot timings . How the bat picks up may help sway you to heavier or light bats. I think a lot of people work on a ideal weight and could probably cope adding or taking away an oz or 2. Anything more than this and I think its then going to start to impact shots and timing.
4oz above your normal bat for me is pushing it, but whos to say what your are used to and comfortable with is right for you? If you are happy with the heavier weight then thats fine. As batsman, we normally find the smallest excuse as to why we arent scoring runs so tend to stick to what we know. Maybe the heavier bat will suit your style
Pages: 1 [2] 3
