Author Topic: Helmets weight database  (Read 13807 times)
SurreySam
Re: Helmets weight database
« Reply #15 on: December 22, 2019, 04:13:39 PM »
Albion special 98 mens standard Titanium grill: 680g
Ayrtek PremierTek Titanium (Adult): 743g
GM Diamond Geo steel Senior 54-59: 725g
GM zelos geo helmet Steel (senior): 736g
GM Purist Geo (Standard Adult): 700g
Gray Nicolls Test opener Steel mens M: 820g
Gray Nicolls Omega XRD steel Mens: 870g
Masuri old helmet steel grill, large: 808g
Masuri Original Series MK II Test Titanium, Medium size: 777 g
Masuri Vision series Elite Titanium mens (58-61cm): 987g
Masuri Vision series Elite Titanium 2019 mens (58-61cm): 917g
Masuri Vision series Test Titanium mens (58-60cm): 860g
Masuri Vision series Test Titanium mens (Large/60-63 cm): 985 g
Masuri Vision series Test Steel mens (58-60cm): 950g
Masuri E-line Titanium senior small (55-58cm): 738g  with thin pad option and no neck guard fitted
Shrey Masterclass Air 2.0 titanium mens (58-60cm): 750g
Shrey Masterclass Air Titanium (Standard Adult): 833g
Wazza08
« Reply #16 on: December 22, 2019, 04:51:06 PM »
@SurreySam - i thought the e-line was just a new name for the elite as t-line would be to Test - but the weight difference seems to suggest it is totally different?
SurreySam
« Reply #17 on: December 22, 2019, 05:20:39 PM »
Yes, Masuri are now trying to simplify branding by using just the first letter:
C line = Club
T line = Test
E line = Elite
For 2020, I think there is one new helmet in the range which I posted a weight for, it's a 2nd E-line model which only has a single shell and the latest eye-line grille. Hence the lighter weight.
So to differentiate the two E-Line models Masuri have gone with :
E-Line (single shell) which as yellow colour band above the ear.
Vision E-Line (twin shell) which has blue colour band above the ear.
I expect the Vision E-line helmet to weigh in the 900g+  region as essentially, its just a renamed Vision Series Elite helmet.
SurreySam
« Reply #18 on: December 22, 2019, 05:32:14 PM »
Oh and I'm returning the small sized E-Line one I have, as it's a tad tight for me.
Instead, I've ordered both a medium sized E-line and T-Line with titanium grilles to try, using the recent discount code posted in the ebay/internet bargains thread.  I'll post up the weights when I get them.
« Reply #19 on: December 22, 2019, 10:38:58 PM »
C line = Club
T line = Test
E line = Elite
I guess it is just easier if they had Club/Test/Elite. The C/E/T-Line is more confusing IMO.
SurreySam
« Reply #20 on: December 24, 2019, 12:48:27 PM »
Masuri T-line Titanium senior medium (58-61cm): 758g  with thin pad option and no neck guard fitted
Masuri E-line Titanium senior medium  (58-61cm): 768g  with thin pad option and no neck guard fitted
SurreySam
« Reply #21 on: December 24, 2019, 01:06:59 PM »
Super service from Masuri so far.  Ordered on Dec 22 at 4pm and the helmets were delivered today; I was expecting them first couple of weeks in January, after the Christmas/New Year festivities were all out the way.
Weights have been added, just got to decide which I prefer. One point to note - I measured my head at 57.5cm and that would be a small, hence getting a small size first but that was just too tight, and would be even more so in the summer heat. The medium is a much better fit for me and I don't even need to add the thick pad option included.
The T-line helmet from what I can tell, is essentially a Original Mk2 Test helmet and vision further out feels better. The E-line has the twin top bar grille and so the top bar appears thicker and eye slot feels narrower once wearing it. However the E-line grille has less upright bars further down, so vision through the grille around your hands/feet and ball contact is improved.  Decisions, decisions.
Also the Masuri neck guard will add 100g of weight give or take a gram, depending on which size bits you use for the helmet.
« Last Edit: December 24, 2019, 01:16:19 PM by SurreySam »
Jaffa
« Reply #22 on: April 09, 2021, 07:34:30 AM »
Can someone please check the weight of the old CS 1-2006 580-610mm Masuri?
I know from Albion helmets that the unpainted ones can be either steel or titanium. The Masuri I have has a unpainted matt metal grille and the weights are 284gr for the grille and 694gr for the helmet.
That points to titanium but I'd like to check. Cheers.
Tell it to my bread in the morning. You just became my backup toaster.
