Pages: 1 2 [3] 4
Author Topic: Is this normal  (Read 6556 times)
Re: Is this normal
« Reply #30 on: June 30, 2017, 03:56:43 PM »
This is true.
So The Doctor's explanation is nonsense?
SOULMAN1012
  • Trade Count: (+25)
Re: Is this normal
« Reply #31 on: June 30, 2017, 04:03:45 PM »
It certainly isn't nonsense no. As was stated 4oz was removed from the bat which is a huge amount, the knot could be below the surface (unusual but possible) also could have been a tiny pin knot until that amount of wood was removed.
B3 are a really good brand so let's be reasonable there is no reason to think they deceived anyone etc, I would imagine a large % of our bats have knots, stains etc under the stickers
GoodLeave
Re: Is this normal
« Reply #32 on: June 30, 2017, 05:40:46 PM »
Appreciate this was a refurb, but wouldn't it have been picked up first time around? It's not like the knot appeared after the stickers were put on.
I find it hard to believe that knots can be covered up by wood growing over them. By all means, prove me wrong. I hope someone does.
skip1973
Re: Is this normal
« Reply #33 on: June 30, 2017, 11:52:47 PM »
A few are acting as though the stickers been moved to a different spot to hide a blemish in some sort of deceitful way. The knot would have always been there, when more wood was taken out some of the eye of the knot ( very brittle ) has come out and been tidied up with filler.
« Last Edit: July 01, 2017, 12:03:07 AM by skip1973 »
Re: Is this normal
« Reply #34 on: June 30, 2017, 11:59:53 PM »
A few are acting as though the stickers been moved to a different spot to hide a blemish in some sort of deceitful way. The know would have always been there, when more wood was taken out some of the eye of the knot ( very brittle ) has come out and been tidied up with filler.
Exactly. FOUR ounces is a LOT of wood. Was a bit cheeky for the original poster to not mention that.
bostoncricketer
Re: Is this normal
« Reply #35 on: July 01, 2017, 01:02:59 AM »
He even mentioned it was a 2 stripe. Haven't seen refurbs carry the stripe sticker.
potzy248
Re: Is this normal
« Reply #36 on: July 01, 2017, 01:29:13 AM »
Seems all legit and the Doctor has been open about it. I just hope you all jump to the defence of other brands when this occurs...
Kane Williamson for Prime Minister.
i12breakfree
Re: Is this normal
« Reply #37 on: July 01, 2017, 02:35:27 AM »
u said it ... completely agree
skip1973
Re: Is this normal
« Reply #38 on: July 01, 2017, 02:53:23 AM »
I find the mental side of it interesting that a bat can be very good but if you find a blemish under a sticker on the back of it, it suddenly becomes no good.
potzy248
Re: Is this normal
« Reply #39 on: July 01, 2017, 04:22:19 AM »
I don't think anyone said that.
Australian fast bowler
Re: Is this normal
« Reply #40 on: July 01, 2017, 05:19:09 AM »
100% agree with this, probably many bats would have had similar things being covered by stickers and unless is the case here you remove them all and refurb, many would be none the wiser,
I do agree however it does not look good. Is the age all thing that many still will go for looks over performance
jimmy23
Re: Is this normal
« Reply #41 on: July 01, 2017, 06:01:01 AM »
It was a 2 stripe big edge warner purchased 8 months ago that I wanted a weight reduction on to which I was advised for it be changed to a small edge warner.
If you read back through the posts I have already said I have no issue with performance or it suddenly becoming a 'bad bat'.
I simply asked if it was normal.
« Last Edit: July 01, 2017, 06:05:38 AM by jimmy23 »
Shinpathy
Re: Is this normal
« Reply #42 on: July 01, 2017, 06:05:11 AM »
I think with extra big sized clefts, you cant expect them to look amazing  :)
Ive got a shocker looker of a kaboom as well, but at least it pings very well.
The Doctor
    • B3 Cricket
Re: Is this normal
« Reply #43 on: July 01, 2017, 08:19:16 AM »
B3 Refurbs will always have the original grade put back on them.
www.B3cricket.com / www.cricketbatblog.com / david@b3cricket.com
Never stand still
skip1973
Re: Is this normal
« Reply #44 on: July 01, 2017, 08:42:45 AM »
i just skimmed back quickly and at least 3 people said they wouldn't tolerate a blemish like this, that CEAT I believe was returned because of blemish as well.
Pages: 1 2 [3] 4
