Author Topic: Can a plank come good  (Read 1053 times)
procricket
  • Trade Count: (+32)
Re: Can a plank come good
« Reply #15 on: February 11, 2018, 08:25:47 PM »
You have to remember lots of big brands press that bit harder on the lower grades as the mark up is not that much...They do not like lower end models coming back.
"Doubt whoever but never doubt yourself"
« Reply #16 on: February 11, 2018, 08:28:11 PM »
when all else fails - how about..... an attempt to convert it into a laminate ?! Not sure how that would be done - I guess you saw it (horizontally) from the toe up (up till a few inches below the splice, then pry it open and glue it back, to replicate what a laminate is? Sounds absolutely insane, but if you have the tools, why not go for it!
« Reply #17 on: February 11, 2018, 08:30:48 PM »
Or just glue a lump of wood on the back
« Reply #18 on: February 11, 2018, 08:55:28 PM »
Depends who using it Cameron!!!
@procricket normally I'd agree but all 6 players unfortunate enough to use it have said it's (No Swearing Please)!
ppccopener
« Reply #19 on: February 11, 2018, 08:58:03 PM »
That would make perfect sense
cricketbadger
« Reply #20 on: February 11, 2018, 09:18:43 PM »
Wine rack is looking like the best shout
Definitely something I'm gonna give a go with a batter old bat anyway
If we don't beat you we'll knock your bloody heads off.
TCA Coach
« Reply #21 on: February 11, 2018, 10:44:36 PM »
Northern what is he difference between a grade 4 UK English willow bat that is dead as an iron bar and a grade 1 or 2 English willow bat that does 'ping'
It's same wood but one has more elasticity than the other? Or is it all to do wi the pressing?
There's normally cosmetic differences but what else if anything separates the grades.
Something I've always wondered.
Id say its down to whos pressing it
No ones ?daft enough to run a genuine grade one cleft through a press without checking it etc
Where as the lower grades are probably pushed through the press on a standard setting, hence you might get some decent pressed lower grades, due to the variances in the clefts.
If I was paying for the clefts, Id be taking extra care with those genuine grade ones, taking care not to over press em
Im sure theres plenty of batmakers press each cleft on merit, but Im fairly sure with others its more of a lottery
